Vehicle Specs
Heb jij informatie over de LJ80, en wil je die delen? Dump het hier! Dit kan varieren van een LJ80 bouwdoos tot een folder, en van een sleutelhanger tot puzzels, vul maar aan!
Vehicle Specs
SJ and LJ series -1972 to 1985 2-door hard and softtop models with many variations available including 2-stroke engines.
Names and pseudonyms of Suzuki SJ and LJ vehicles.
LJ series AKA: Hopestar, LJ10, LJ20, LJ50/55, LJ80/81
Styles: Hardtop, Convertible, Pickup; 2 Seater, 3 Seater, or 4 Seater; 2 Door Manufactured: 1970-1977
SJ series AKA: SJ20, SJ30/40, SJ410, SJ413
Styles: Hardtop, Convertible, Long Wheel Base, Pickup; 4 Seater; 2 Door, 4 Door
Manufactured: 1977-1984
LJ
Hopestar ON 360
First released: 1968
Engine: air-cooled, 359cc, 2 cylinder, 2-stroke
Horse Power: 21 hp @ 5500 rpm
Max. Torque: 31.4 Nm @ 3500 rpm
Wheelbase: 1.95m
Dimensions (mm): 2995 (L) x 1295 (W) x 1765 (H)
Weight: 625 kg
Roof: Soft top only.
Notes: Original Suzuki 4WD truck, manufactured by Japanese Hope Motor Company. Only 15 vehicles
ever produced..
LJ10
First released: 1970
Engine: air-cooled 360 cc, 2 cylinder, 2-stroke
Horse Power: 5 hp @ 600prm
Max. Torque: 33.4 Nm at 5500rpm
Fuel Tank: 26L
Notes: Engine size and length/width were regulated by Japanese Transportation Guideline to keep
vehicle classed as "mini-car". Spare tire was stored behind driver's seat to conform to guidelines,
making it only a 3 seater. Most distinctive feature is horizontal grill, with Suzuki emblam in middle
bar.
LJ20A/E
First released: 1972
Engine: watercooled 360cc, 2 cylinder, 2-stroke
Horse Power: 268 @ 5500rpm
Max. Torque: 37.3Nm @ 5000rpm
Fuel Tank: 26L
Roof: Soft top and hard top
Notes: First Suzuki 4x4 to be exported. Minor cosmetic changed from LJ10 body style. LJ20A models
included 2 amber lights (parking light and turning signal) on each side of the front, E models on had
one combo light.
LJ50/55 (Jimny 550/SJ10)
First Released: 1976
Engine: 539cc, 3 cylinder, 2-stroke
Horse Power: 35
Max. Torque: 52Nm @ 3000rpm
Transmission: 4 speed
Fuel Tank: 26L
Dimensions (mm): 3010 (L), 1295 (W)
Ground clearance: 237mm
Weight: 670kg (S/T) / 720kg (H/T)
Roof: Hard top and soft top
Notes: 2 speed transfer case; motor had a motorcycle type oil pump so no fuel had to be pre-mixed; it
had a plastic pipe running from the heater fan motor housing to the distributor and then to the clutch
housing - the idea was when crossing deep water you turned the heater blower on and this pressurised
the distributor and the clutch housing thus keeping the water out!; on-road cruising speed was about
80km per hour, it could manage 110km per hour with a tail wind; spare tire was finally moved to rear
gate; top front singal light was changed from amber to clear; new gril and raised hood.
LJ80 (SJ20)/LJ81
First Released: 1977 (series II - 1979)
Engine: 797cc, 4 cylinder, 4-stroke
Horse Power: 42 @ 5500rpm
Max. Torque: 61Nm @ 3500rpm
Fuel Tank: 40L
Axle Width (mm): 1190 (F), 1200 (R)
Roof: H/T & S/T. Note: Series II S/T came with metal doors only.
Notes: Ute/Pick-up model known as LJ81; first Suzuki truck exported from Japan to North America.
The only distinguishable differnce between the LJ80 and the LJ50 is that the LJ50's speedometer
goes to 90km/h and the LJ80's goes to 110km/h.
SJ
The first SJ model (SJ10) was the same as the LJ50. The SJ20 was more like the LJ80. The SJ410
(SJ30) had a totally diffent body.
The SJ was the first 'sammy-like' model. Some of it's original body panel designs are were used in the
Samurai/Sierra bodies. In fact some people confuse the SJ410 with the Samurai/Sierra, however the
SJ has a distinctive vertical slat grill. They were the first Suzuki vehicles to use a newly developed 1L 4
stroke, 4 cylinder. The SJ410W was the first Long Wheel Base Suzuki truck and incorporated a
removable hard fiberglass roof. At over 4 metres in length it was put into service by numerous 3rd
world counties as a military j**p. The LWB and Pickup models were not released until 1982.
SJ20 (SJ10 see LJ50)
Engine: 797cc, 4 cylinder, 4 stroke
Fuel Tank: 40L
Length: just over 3 metres
Width: 1.295 m
Ground clearance: 237 mm
Weight: 670 kg (S/T) / 720kg (H/T)
80km per hour, it could manage 110km per hour with a tail wind (if you could stand the noise!)
SJ410 (SJ30/40)
First Released: 1981 (LWB and Ute models released in late 1982)
Roof: H/T & S/T.
Notes: Also came in Long Wheel Base (LWB) S/T and Pickup (Ute) models and in a 4 door version
based on the LWB chassis
Bron: Zukiworld.com
